Anuncios
CREATING AN ISOLATED ELEVATION
No aplicable
I have done this in the past, but man it has been years.
I have a floorplan that I am working with. I want to create an elevation view of one wall without everything else in the viewport.
There is a command  to point to a certain wall or objects, and only those objects are visible, other than using the new Layout Base View.
Anyone remember this one?
Thanks in Advance !!!
James
0 Me gusta
Responder
Soluciones aceptadas (1)
721 Vistas
5 Respuestas
Respuestas (5)
No aplicable
AutoCad 2017 is my current software
0 Me gusta
No aplicable
I use a routine that uses the DVIEW CLIP function to quickly cut clipped views through 3D models.
Search for DVP.LSP, I've posted it a couple of times lately.
0 Me gusta
john.vellek
HI @Anonymous,
Are you trying to use LayISO or HIDEOBJECTS for this workflow? Or Perhaps VPLAYER Freeze?
3DClip might also be useful.
John Vellek
0 Me gusta
imadHabash
maybe MVSETUP will help...
Imad Habash
0 Me gusta
No aplicable
Solución aceptada
As john.vellek points out LAYISO or maybe _ISOLATEOBJECTS, Layiso will isolate by layer while _ISOLATEOBJECTS will isolate by object.
3DCLIP will place cutting planes wither side of the 3D wall to provide a true elevation of the wall.
The DVP.lsp I mentioned (find it HERE) is a fast way to set those 3DCLIPping planes.  Watch the video, there no sound, but it shows selecting two points in one view to locate the clipping plane and a third pick for the viewport in which the clipped view will land.
