Creating an arc from tangent of circle to line.
zoltanferenczi99
zoltanferenczi99
I am trying to create a curve that would look like a fillet between an arc that is connected to a line. I need the curve to line up with the tangent of the arc to the line directly so it flows from line to arc. Been messing with many commands to no avail. Posted pictures of what I need it to look like.
neaton
Try the Circle, TTR (Tan Tan Radius) command. At the prompt select the line and circle. Once the circle is created use the trim command to remove the unwanted lines.
imadHabash
Hi.
There are many ways to get what you ask for . by TRIM and FILLET you will get it also. a make a simple screencast  sample that describe your issue.
Imad Habash
zoltanferenczi99
Thank you! Filleting by radius of 0.5 was what I was missing. Tried tan-tan radius as well, both worked nice. Appreciate the help.
