Creating a surface or solid from 3D lines
I am trying to create a "P"rimitive Triply Periodic Minimal Surface on Autocad.
I have a question;
Is there a way to avoid this sharp line effects on my surface ? I used LOFT comment to create this surface.
If there is anyone who is interested in creating TPM Surfaces i would like to take advices and helps.
Sincerely,
Aytac.
5vvD6Ef
This is my work,
 This is how it should look like.
Alfred.NESWADBA
look to that video, does command _FILLET between 3 cylinders work for you?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thank you for your answer. Yes, looks beautiful but i need a surface more than a 3d solid. I have tried the
Is there a way to convert it to a surface?
Alfred.NESWADBA
Command _CONVTONURBS as shown in the attached video ...
- alfred -
Alfred NESWADBA
It has perfectly worked!
Thank you so much.
Greetings,
Aytac
