Creating a dynamic legend with fields
Hello
I am trying to create a legend using insertable blocks. The aim is to have a block that when inserted will prompt for a few entries of information and calculate some values. Namely:
Field entries:
  1. Item no - to be entered by user
  2. Quantity - to be entered by user
  3. Power value one - to be entered by user
  4. Power value two - to be entered by user
  5. Total power - to be calculated as quantity x (sum of 3+4)
Can anyone suggest how I might achieve the above?
Thank you
pendean
Community Legend
Community Legend
You will need to customize with LISP if a simpler predefined TABLE object (where you users are trained to enter the required data) is not an option.
Can you show us a sample as a DWG file?
Hello - file attached. The aim would be to add in another "column" for the load total. Then make each option for connections a pull down option list of standard text. Unless you could add pull down options in a cell within a table, much like callouts in excel?
jeff_rivers
How about creating the entire legend & calculations in Excel, then using the <Link Data> command on the Annotate ribbon to link to and insert the Excel as a table in your drawing.  Then if any entries have to be edited or updated, once the Excel file is edited and saved, the Data Link will update the drawing automatically.
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Hello
Yes that is the way we currently do it. Unfortunately this causes us a lot of problems when transferring drawings to other companies. Some don't use excel, some only use cad 2010 etc.
