creating a downloadable block
No aplicable
So i am creating a drawing fir a designer's web site. She is needing a 3d drawing block to put on her website so that clients can dwnld the block and place in their floor plans to see how it looks.
I created the drawing, now i need to create the downloadable block for her website.
Thanks fir all the help guys!
0 Me gusta
Responder
355 Vistas
5 Respuestas
Respuestas (5)
imadHabash
.dwg CAD extension is what all AutoCAD users can deal with. and your needed block is a part from any .dwg CAD file . so you can upload your 3D drawing as .dwg CAD file OR make it as a block with BLOCK command in your .dwg file . if i missed your need please come back and describe more your issue .
Imad Habash
0 Me gusta
pendean
Community Legend
Community Legend
A 'block' is just a DWG file with only one 'design' in it: there is no specialty external file format for blocks in AutoCAD.
0 Me gusta
No aplicable
To be honest... im not sureexactly. Its been years since ive used these programs in school and im needing to do things now that i have never learned.
I jusr remember using revit and downloading blocks for furniture and opening them into a floor plan drawing and this is what this designer wants.
Thank you so much for the help & the info!
0 Me gusta
gotphish001
Open a blank drawing, draw what you want the block to be, use BLOCK command to make what you drew a block, save drawing and your done. You can then upload that drawing. If you want to make more than one block at a time, you can draw the block and then use the command WBLOCK, tell it where to save it and then upload the saved file.
Nick DiPietro
Cad Manager/Monkey
0 Me gusta
Kent1Cooper
@gotphish001 wrote:
Open a blank drawing, draw what you want the block to be, use BLOCK command to make what you drew a block, save drawing and your done. ….
I would suggest you not  use the BLOCK command to make what you drew a Block inside the drawing file -- if you do, when someone downloads and INSERTs that drawing, it will become a Block with another  Block nested inside it unnecessarily.  Just leave what you drew as a .dwg file, and it will become a [non-nested] Block definition when INSERTed into another drawing.  BUT do  absolutely use the BASE command  in that drawing, to define the location in the drawing that will become the insertion base point when someone uses it in an INSERT command.
Kent Cooper, AIA
0 Me gusta
