Creating a dimension style
AutoCAD_Oozer
AutoCAD_Oozer
I like to create dimension styles by
-placing dimensions on objects
-clicking the dimension, setting up the properties to my liking
-using "match properties" to assign the properties to any other dimension lines I want to look like the original.
Can I set up dimension line properties for a dimension line and then somehow import it into the dimstyle manager so I can have it as a style without having to match properties to edit all other dim lines?
Am I doing this the wrong way?
I find it difficult to make a new dimstyle first, have to guess what everything is gonna look like on the page then make edits to it by going into the dimstyle editor over and over again.
teixeiranh
Hello sir,
"Can I set up dimension line properties for a dimension line and then somehow import it into the dimstyle manager so I can have it as a style without having to match properties to edit all other dim lines?"
Unfortunately not.
Take a look at the properties of the dimension that you like.
While defining the new dimension, use those properties.
This is the best workaround that I know.
Hope it helps!
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
scot-65
Do your trial and error for the desired settings by
first adjust the settings, one by one, then create a
new dimension object along the way.
When satisfied, command -DIMSTYLE "Save" and give it a name.
If there is one existing dimension object that is to your liking,
command LIST and take note of all the overrides.
Enter these overrides and the associated values one by one
on the command line. From there, add a new dimension object
as a check.
One of the first items to investigate and memorize when first
exposed to an AutoCAD editor is to understand all the
dimension variables. This was at a time before the dimension
dialog.
After time you will understand that there is one dimension
variable that is adjusted that will make the dimension object
proportional to the drawing scale. Hint: DIMSCALE
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
teixeiranh
Nice post!
Could you please demonstrate that (screencast)?
cadffm
What you want to see what you dont see whenn you do it?
Create new dimension object how you like,
use LIST, now you can see the properties / which are named by there variables
Now you can set the variables values current an save your current (temporary) dimstyle,
-Dimension
save
MyNewStyle
voila
A dimension style is only a saved config for many of variables, so you can switch between with one click and without type-in every time hundreds of setting.
command: setvar ? dim*
[F2]
draw dimension, edit it like you want..
command: LIST
1 gefunden
                  BEMASSUNG  Layer: "0"
                            Bereich: Modellbereich
                    Referenz = 58a
assoziativ: nein
Typ: horizontal
1. Hilfslinie  Definitionspunkt: X=1872.0212  Y=1624.8360  Z=   0.0000
2. Hilfslinie  Definitionspunkt: X=1887.9922  Y=1624.4160  Z=   0.0000
Maßlinie Definitionspunkt: X=1887.9922  Y=1635.4751  Z=   0.0000
Vorgabe Textposition: X=1880.0067  Y=1635.4751  Z=   0.0000
Vorgabetext
Bemaßungsstil: "Standard"
Bemaßungsstil überschreibt:
 DIMASZ      0.2500 ; different to current style
 DIMTXT      0.3500 ; different to current style
Beschriftung: Nein
command:
command: DIMASZ
Neuen Wert für DIMASZ eingeben <0.1800>: 0.25
command: DIMTXT
Neuen Wert für DIMTXT eingeben <0.1800>: 0.35
command: -DIMSTYLE
Aktueller Bemaßungsstil:  Standard   Beschriftung: Nein
Aktuelle Bemaßungsüberschreibungen:
 DIMASZ      0.2500
 DIMTXT      0.3500
Option für Bemaßungsstil eingeben
[Beschriftung/SIchern/Holen/STatus/Variablen/Anwenden/?] <Holen>: _save
Namen für neuen Bemaßungsstil eingeben oder [?]: MyNewStyle
Test your work
command: DIMLINEAR
Sebastian
teixeiranh
Got it!
Thank you so much for the explanation!
