Anuncios
creating a custom linetype
No aplicable
Good day everyone. I wanted to see if anyone could offer some inside in how to create a custom linetype for sewer lines, and I am not allowed to use letters in such lines. For now I've just created a line, offset it x distance both ways, hatch it, exploit the hatch and the re hatch every other. This process is very time consuming and when ever I have to make changes makes me wish I had discovered this forum before lol. I am attaching a sample foto of how I would like to linetype to look like to see if it is even possible or not.
(ideally would be the third one from the top, because it seems that represent better a flow of direction.)
0 Me gusta
Responder
946 Vistas
4 Respuestas
Respuestas (4)
imadHabash
HI,
for such cases of line types the most powerful and practical way is to use either ARRAY or Dynamic block.especially when colors and thickness are used.
Good Luck..
Imad Habash
TheCADnoob
I created a screencast showing how one could create this line. There were a couple bumps edited out. (mainly the complexity of the shape) first you make the shape and then you use the shape when you make the linetype.
As @imadHabash suggested there may be better ways to achieve this if you are looking to have it look like the picture you provided. I frequently use array path to create things that look like lines and its fairly easy to work with.
CADnoob
No aplicable
Thank you very much. I will try it out today and will let you all know if it works. it seems like I should be able to do it, but my CAD has a Carlson Software add-on that sometimes does not like or works well whit some stuff or either my boss taste lol.
Thank you all again
0 Me gusta
TrevN
Just curious, but why can you not use letters with these lines?
0 Me gusta
