Creating a 3D solid from lines (Help)
Hi, I created a 3d object using the line tool but it shows just the outlines I made. I need help in changing the object to have solid faces all round..
Alfred.NESWADBA
create 2 polylines (set your UCS before to be vertical and at the correct plane-Z) then run command _LOFT between these 2 polylines.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
