01:14 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I need to create a custom hatch pattern much like
*AR-B816, 8x16 Block elevation stretcher bond
0, 0,0, 0,8
90, 0,0, 8,8, 8,-8
My pattern needs to be 12" wide x 4" high & the vertical line on the second row will be halfway between the 2 vertical lines on the first row. Its basically like a brick pattern. i believe that's called a running bond pattern. Normally a brick pattern is 8" wide x 2-1/4" or something. i need it to be 12x4. i used to have something that explains all the steps such as what line is the angle, etc. Can anyone walk me through this? it should be a simple pattern but i cant remember the syntax i need to put in.
