Turn DYNamic input off and try. If that was it, you have to enter input differently in recent versions.
To Specify Relative or Absolute Coordinates in the Dynamic Input Tooltip
From <https://help.autodesk.com/view/AMECH_PP/2019/ENU/?guid=GUID-AE225073-2ECD-41CC-9B8A-61743E8CFBA9>
GrantsPirate
Piping and Mech. Designer![]()
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
In addition to what @GrantsPirate said, if you are using the default settings for dynamic input, then if you wanted to create a point entity, here are some example entries.
An easy variation to remember for placing a point relative to an existing point is to use copy. No @ is necessary whether dynamic mode is on or off. For example, to copy a point 2.5 units in a direction of 30° just type the following:
Command: COPY [Enter] -- then select the point to copy
Select objects: 1 found
Select objects: [Enter]
Current settings: Copy mode = Multiple
Specify base point or [Displacement/mOde] <Displacement>: 2.5<30 [Enter]
Specify second point or [Array] <use first point as displacement>: [Enter]
