create multi layouts in paper space
Message 1 of 12
I'm working in a big project that i need to have a many layouts in a paper space, however I can make layout and then enter the viewports and move it to my drawings, but i need to do that for each one as I have more than 500 drawings in model space, is there any command or lisp routines that will make a shortcut for this.
I did some research and I have found a YouTube video that will help me, but the thing is not working
I will post the youtube video so you will understand what I need.
https://www.youtube.com/watch?v=MFzlVaJIfEs
thanks in advance,
Waseem
Replies (11)
Message 2 of 12
maratovich
No problems.
All this does automatically:
AutoViewport - Automatic creation layouts and viewport
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 3 of 12
this program is not free, however i downloaded the trail one, and was working on it for couple hours, the problem that I'm facing is my template cant change the numbers same as the video when he changed  from new text to be pages inside the template. please advice on how i can change the numbers of my template to be continues number like 1,2,3....
instead of doing it manually by changing each one.
Message 4 of 12
maratovich
Give us an example of your dwg file.
www.kdmsoft.net
Message 5 of 12
I've attached a test file, the text on my template which is wwe-01 cant change it unless one by one, my project have more than 500 layouts.
please advise if you have any Lisp command to do that or same program.
Message 6 of 12
maratovich
Here is an example.
If you need to refine - write to the mail developer.
www.kdmsoft.net
Message 7 of 12
, I've done this which is not my issue, my issue is when I create the layouts I already have my own template the same attached I sent you, that template has same text which is attribute and it didn't change to be continuous numbers, I have to do that one by one, is there any Lisp to make the existing numbers or text to be sequences?
regards,
Message 8 of 12
maratovich
Yes. This is possible.
Watch the video.
www.kdmsoft.net
Message 9 of 12
that's a great program to do all of these, except that I downloaded the program but it got deleted because of the virus program that is in my computer, however I've more than 20 computers in the office I can't risk all of the computer because of that program also I should buy it. first program worked perfectly with no issue, I just have to find a Lisp routine to do that attribute to be in sequences numbers. I accepted your solutions and hard work for me, but if you have any Lisp routine to do that I will appreciate it. thank you sir
Message 10 of 12
maratovich
NO VIRUSES !!! This is a commercial product and cannot contain a virus. Checked by all antivirus.
Do you use cheap free antivirus?
What antivirus do you use?
www.kdmsoft.net
Message 11 of 12
maratovich
Here is the official report of the antivirus.
There are no viruses.
We have processed your request (tracking number # 42908828), and your application is now closed. Below is a report of our results for the files in your view:
Developer Notes:
1. Revers eng.zip is a container file, such as an archive, email
2. ReversForm.exe is not malicious.
3. Revers.exe is not malicious.
4. pcnsl.msg is a data file that is not considered malicious.
5. pcnsl.exe is not malicious.
www.kdmsoft.net
Message 12 of 12
degrootm9RSLH
Community Visitor
Community Visitor
Is this a lisp routine? How can I get this to implement on my computer? Is there a download for this?
