Create mesh between two curved pipes in AutoCAD
alecia3567P
Message 1 of 17
alecia3567P
How can a create a thin mesh wire between two piping in 3D? I am trying to create a wire mesh wall that is btween the two pink pipes and I need it to follow the path
 @alecia3567P
john.vellek has edited your subject line for clarity: Help needed ASAP.
Accepted solutions (3)
Replies (16)
Message 2 of 17
john.vellek
Hi @alecia3567P,
Without seeing the actual drawing it is hard to say what might work but perhaps a LOFT would do the trick.
John Vellek
Message 3 of 17
Patchy
Mesh wire look? draw 3dsolid then apply the material.
Message 4 of 17
alecia3567P
Explain to me what a loft is?  I attached the file
Message 5 of 17
j.palmeL29YX
Do you need a vertical mesh between the upper pipe to the lower pipe (see attached .png)?
If no, please explain more detailed where you need a mesh. If yes:
Unfortunately you deleted the splines from which the pipes were made. If you can recreate these splines, start the loft command, pick the two splines and finish the command. You will get a surface. Then attach a suitable material to the surface and you are ready.
If you have lost the splines irretrievably, ask again.
cadder
Jürgen Palme
Message 6 of 17
alecia3567P
I didn't lose the spline but when I do the loft command it des not close and removes the loft.
Message 7 of 17
alecia3567P
My splines are still exitestent but when I use the loft command it is not closing & completing the loft.
Message 8 of 17
alecia3567P
Yes a vertical mesh between those pipes. I know it a simple command but I am not getting any luck.
Message 9 of 17
john.vellek
HI @alecia3567P,
Can you send me a drawing with just the two splines?  I see the geometry I have been playing with in your first file is not very clean for the bottom path.  It might be fastest to trace over the bottom spline with a new one or a new 3dpoly and then create the LOFT.
John Vellek
Message 10 of 17
alecia3567P
Yes give me  a sec.
Message 11 of 17
alecia3567P
Here is a file with the splines to the right
Message 12 of 17
alecia3567P
Message 13 of 17
john.vellek
Hi @alecia3567P
I was still having some problems with your splines.  For illustration, I simply created some 3DPOLYs on top of your linework and then I was able to loft. I have attached my file but you might want to make your 3Dpolys more precise than I did.
John Vellek
Message 14 of 17
j.palmeL29YX
Hi alecia,
what we need are this two splines (or 3DPlines) - see attachment PipePath. Where are they coming from, how did you create the path for your pipes? How did you create the pipes (The upper is only one surface, the lower a bundle of many surfaces)? Based on the current informations it is hard for us to recreate where you wish the path for the pipes.
Furthermore: Where do you wish the mesh, Pos1 or Pos2 or any other? (see attachment MeshPosition).
And generally: for such pipes you should prefer Splines instead of 3DPolylines. Your pipes don't look good.
cadder
Jürgen Palme
Message 15 of 17
john.vellek
Hi @alecia3567P,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 16 of 17
j.palmeL29YX
Based on the given informations I modelled this:
- you need two splines along the pipes (as path), I reconstructed it from the given geometrie (approximately). 'Some of your splines (maybe all, i didn't check it) are self overlapping and therefore they can not be used for a good lofting)
- loft from spline_1 to spline_2
- sweep a circle along the splines
- attach material of your choice
cadder
Jürgen Palme
Message 17 of 17
alecia3567P
Thank you very much. This was very helpful.
