CREATE LINES/POLYLINES THAT AUTOMATICALLY HAVE LINE/CURVE LABEL ADDED TO THEM
NmiglioriCadLad
Message 1 of 8
NmiglioriCadLad
Greetings! i'm looking for a  way to create a line/poly line that automatically has line/curve labels added to them. this would be particularly helpful when drawing property boundaries or when using lines/curves to check dimensions
Replies (7)
Message 2 of 8
Patchy
Then use Civil 3D, plain autocad can do it with autolisp, but it will not label arc definitions (Arc length, chord, bearing....for you)
Message 3 of 8
JBerns
@NmiglioriCadLad,
Please attach an example drawing  containing a "Label". This would be very helpful. What content do you want seen in the label?
If it is civil related, there may be better tools than plain AutoCAD as mentioned by @Patchy .
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 4 of 8
NmiglioriCadLad
I am using autocad Civil 3D 2021. I am looking for a function or an option or maybe general education to be able to draw a line or curve and have a label style immediately applied to the line or curve. effectively eliminating the need for me to cancel out of my poly line creation command to apply a label to the feature. pictured below is an average example of what what i would draw using these lines and labels. note that lots of these features could include 50+ courses, so having a feature that automatically labeled my lines/curves as i drew the line/curve would be HUGE
Message 5 of 8
Pointdump
Hi Nicholas,
"...have a label style immediately applied to the line or curve."
Even in Civil 3D that won't happen. Labels are applied after the fact. But Parcel Labels can be applied all in one fell swoop so there's that.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 6 of 8
RobDraw
You should be asking in the C3D forum.
Rob
Message 7 of 8
3wood
You can also try ADDLINES.
It doesn't curve the annotation above arc though.
Message 8 of 8
parkr4st
C3D would do that if you used FDO objects such a .sdf or .shp data with the label style assigned in the style.
