create hatch from autocad point object
Maybe I have missed a command ... or maybe some clever soul has made a tool for this job ...
The images below should a whole lot of autocad point objects in a drawing.
When you zoom out ... it looks like a filled hatch.
Is there a command that creates hatch from point objects?
Or has somebody made a Tool to create a htach from point objects?
Alfred.NESWADBA
Not sure to understand you correct, are you looking for a hatch pattern looking like points. Yes there is one, the hatch pattern is called "DOTS".
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
No. I am looking for a command that generates a hatch from existing point objects. Or ... a command that will generate a boundary from existing point objects.
Alfred.NESWADBA
Ok, now I do understand the question.
What ideas I have to that:
  • if you have a GIS application you can do that using a buffer analysation ==> buffer around a point will be a circle, then running a union with all circles gives polygon(s)
  • If you have something like Civil 3D you can create a triangulation around the points (like for building a surface based on elevation points) and then take the outline of the surface.
- alfred -
Alfred NESWADBA
Thx Alfred ... I will see what I can find based on your input...
