Create Custom Hatch?
riosdesigns
riosdesigns
I need to create a custom hatch for roof tile. It is just taking way to long as a block. Can anyone help? I have inserted it for review.
Patchy
Go to Dimensioncad , register and get it for free.
o_van_ooster
Community Visitor
Community Visitor
When you have made a block of the pattern you want to hatch, you can go to "Express tools" at the top of your screen, then go to super hatch. There you can select your own block, and make it into a hacth, you'll have to set the scale first, but if your original block was the right scale, than just type 1 for both the x and the y scale. Then it'll ask you to select the area, after which you can use your pattern as an hatch. Its quite simple and very usefull, hope this helps.
