Create an alias combining a command and prompt
cshermanRLQ8L
Observer Observer
cshermanRLQ8L
Observer
Observer
I would like to create a shortcut for a command that bundles in a specific option that appears after starting the command along with the command itself. For example, if I wanted to make an alias for UCS that automatically calls the [World] option after starting the command, is there a way to call both the command and the option in a single alias, or can I only create an alias for the master command?
paullimapa
Alias can only support a single command.
But you can always create a lisp function and use that as alias.
For example assuming you currently don't have an alias called UW, then you can create a lisp function UW like this:
(defun c:UW ()(command"_.UCS""_World")(princ))
Paul Li
IT Specialist
@The Office
