Create a GENERAL FILE w an xref that contains another xref (xref tree)
Matteo_Dossetto
Message 1 of 33
Matteo_Dossetto
Dears,
I am facing this issue with complex files.
I have a layout C that has to be inserted in a layout B.
This layout B has to be inserted in layout A and I want that the B file inside the A file shows the C file.
In few words I need to create a tree of xref but looks not possible on this file.
Could you please help me?
Replies (32)
Message 2 of 33
atGK8NU
Make sure Layout C is an attachment, not an overlay. If you already overlaid it in Layout B, you can change it in the xref palette by right-clicking.
Message 3 of 33
cadffm
Make sure Layout B is an attachment, not an overlay. Make sure LayoutC is ATTACHED to LayoutB
If you already overlaid it in Layout A, you can change it in the xref palette by right-clicking.
@Matteo_Dossetto
[F1] About Nesting and Overlaying Referenced Drawings
Sebastian
Message 4 of 33
paullimapa
When you say “layout” hopefully you’re referring to the drawn objects in “Model” tab because you cannot insert or in your case xref any drawn objects that only exist in any of the “Layout” tabs.
Paul Li
IT Specialist
@The Office
Message 5 of 33
Matteo_Dossetto
Exactly, simply there are three dwg drawings A B C that have to be inserted one in another in another
Message 6 of 33
Matteo_Dossetto
I did it now dwg C as attachment in dwg B, and dwg B overlayed in dwg A but it does not work and there is no xref tree generated.
I see that normally to generate it the process is easy, overlay C in B, and than again overlay B in A but it does not work here, I wonder why
Message 7 of 33
cadffm
Is this screenshot from fresh opened Drawing C
Show us a screenshot of dwgB please.
Sebastian
Message 8 of 33
Matteo_Dossetto
This is the naming
Message 9 of 33
cadffm
Sorry, I meaned:Is this screenshot from fresh opened Drawing A
And again:
Show us a screenshot of (xref dialog) in dwgB please.
Sebastian
Message 10 of 33
Matteo_Dossetto
No as you can see the principal file in the external ref menu is referred to the A the one opened here
Message 11 of 33
cadffm
"Same picture", but from dwgB, while  details about xref C are open.
Sebastian
Message 12 of 33
Matteo_Dossetto
Got it
Message 13 of 33
paullimapa
Could you share these three dwgs here for us to try?
Paul Li
IT Specialist
@The Office
Message 14 of 33
Matteo_Dossetto
Sorry Paul but I can't. Could you please explain to me how I could do it or, Send me three files linked each other w/ a tree and I can verify how to do it or reply it?
Message 15 of 33
paullimapa
Straight forward process:
Open dwg B (Xref-B.dwg)
XAttach dwg C (Xref-C.dwg)
qsave
Open dwg A (Xref-A.dwg)
XAttach dwg B (Xref-B.dwg)
Then you'll have a tree in dwg A (Xref-A.dwg) with dwg B (Xref-B.dwg) and dwg C (Xref-C.dwg) as nested
Paul Li
IT Specialist
@The Office
Message 16 of 33
Matteo_Dossetto
Question how to do file C "nested"?
Message 17 of 33
Matteo_Dossetto
I retried this method with xattach command from keyboard but nothing, UCS and units are the same, shoulde make the tree but does not happen (either on my personal laptop and company laptop and also with different files)
Message 18 of 33
paullimapa
Again, unless you're able to share your dwgs, it's difficult for us to help you troubleshoot.
Perhaps there's something in dwg C that is preventing you from xref attach into dwg B
Then you'll never see it nested when you attach dwg B into dwg A.
But in dwg B after you attach dwg C in the External Reference palette you should be able to see dwg C listed. But if you don't that's the problem you'll have to solve first.
Paul Li
IT Specialist
@The Office
Message 19 of 33
Matteo_Dossetto
Here are the files
Message 20 of 33
paullimapa
You have circular references meaning one file referencing each other.
This is what's preventing the nested tree to show up in dwg 1.
Once you detach them from each dwg then you'll have a tree in dwg 1
Paul Li
IT Specialist
@The Office
