Anuncios
Crashed drawings
apanbasu
Crashed drawings
apanbasu
I have received the attached E-transmit file and after unzip I converted the file o 2007 version. First time when it failed - iasked the sender to send me again. the attached is the second file. Whenever I tried to open the file the software crashes with fatal Error (See attached) I ran Recover and and it came out OK and then when it tried to open - it crashed.
I repair the AutoCAD 2008 and without luck.
The gentleman send me two more drawings and they were fine.
Will somebody help me ? What should I do to open the drawing?
Thank you.
0 Me gusta
Responder
Soluciones aceptadas (2)
847 Vistas
12 Respuestas
Respuestas (12)
Alfred.NESWADBA
Do I understand you correct, you are working with AutoCAD 2008?
If yes ask the sender of the dwg-file to use command -EXPORTTOAUTOCAD to save his drawings back to DWG2007, and this needs to be done with all files, also with the referenced ones.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
...or you can correctly knock down the files yourself to 2007dwg file format with the DWGTRUEVIEW free viewer and it's DWGCONVERT feature https://knowledge.autodesk.com/support/dwg-trueview/learn-explore/caas/sfdcarticles/sfdcarticles/How...
0 Me gusta
pendean
Community Legend
Community Legend
apanbasu
The drawings were made in 2014 LT. when I received E-Transmit file I
converted to 2007 version using Drawing Truview 2018. I can open this
drawing in Trueview. Unfortunately, I cannot save the opened file in
Trueview. There are three separate e-transmit files were mailed to me. After
conversion, I had no problem opening two of them This drawing is giving me
trouble. I have requested to save the drawings in 2007 version and mail me
the drawings. I have not received the converted drawings yet. Let me see
what happens when I have the drawing.
0 Me gusta
pendean
Community Legend
Community Legend
>>>... I cannot save the opened file in Trueview...<<<
Why not? We all can and do all the time
apanbasu
I did every thing suggested. I had the drawing saved in 2007 version and saved the drawing in different name. Still it crashed. I do receive drawing from this gentleman regular basis and occasionally I had a situation where symbols may not show. That is resolved by blowing out the symbols and save the drawing in 2007.
But, this one will not budge. I have attached the drawing. if somebody could help.
0 Me gusta
ennujozlagam
Solución aceptada
can you try these 2 files attached, if works to you. thanks
pendean
Community Legend
Community Legend
Solución aceptada
See attached.
HTH
apanbasu
Thank you. Thank you both. I do not know what you did - it worked. Can you tell me what you did that I can I do if this happens in the future. Otherwise I will lean on you guys. Stay there as long as I am kicking.
Thanks again.
0 Me gusta
pendean
Community Legend
Community Legend
I used the AECTOACAD command in AutoCAD2019 to knock your files down (the program I already had open on my PC at the time), not much else really.
0 Me gusta
Alfred.NESWADBA
Strange ... have you ever looked to post 2 in this thread?
- alfred -
Alfred NESWADBA
0 Me gusta
apanbasu
I did nor mean to offend you in any way. In my post I stated both solutions. I did not realize I need to check both posts for the solution.
Thank you.
0 Me gusta
