Couldn't open dxf file
I created a dxf file using creo parametric 6.0.4 . when trying to open it through the autocad (2014) , i asked to press enter. I received the following message ("Unknown value "AC1032" encountered in drawing version.
Invalid or incomplete DXF input -- drawing discarded.")
dbroad
Sounds like the problem is with creo parametric 6.0.4
Architect, Registered NC, VA, SC, & GA.
file and error message
8XXXNNJH7KT6
AC1032 is AutoCAD 2018 and newer format, so AutoCAD 2014 can't read it.
8XXXNNJH7KT6
I should also add that you can use DWG TrueView (which is a free download) to open your dxf file and save it to an older format dwg/dxf file that your AutoCAD can read.
