Here's the scenario:
I have several groups mixed in a common area shared with "loose" geometry. I group those groups, along with the loose geometry into a single group. So now I have a group that contains sub-groups.
Say I now want to copy one of those sub-groups to another place in the drawing. As far as I know, I have two options.
1 - Ungroup the conglomeration, copy my desired sub-group, then re-group the collection.
2 - with Pickstyle set to 1, select one item. It selects the entire collection, but also gives a grip for the sub-group that object belongs to. Using Ctl+Pick Grip, I can copy that sub-group out of the collection.
Is there a better way than either of these two methods?
Solved by ВeekeeCZ. Go to Solution.
Although I do think that #2 is quite a good solution, here is another one.
It's a LISP. Look HERE in case you don't know what to do with it.
Run the lisp first, pick an object, select a group. It stays pre-selected for the next job.
(vl-load-com) (defun c:SelectNestedGroup ( / e d s l e done) (if (and (setq e (car (entsel))) (setq d (entget e)) (setq d (member '(102 . "{ACAD_REACTORS") d)) (setq d (mapcar 'cdr (vl-remove-if-not '(lambda (x) (and (= (car x) 330) (= (cdr (assoc 0 (entget (cdr x)))) "GROUP"))) d))) (princ (strcat "\nObject is part of " (itoa (length d)) " group/s.")) (setq s (ssadd)) ) (while (and (setq l (mapcar 'cdr (vl-remove-if-not (function (lambda (x) (= (car x) 340))) (entget (car d))))) (> (length d) 1) (not done) ) (foreach e l (redraw e 3)) (initget "Yes") (if (getkword "\nSelect this group [Yes, please] : ") (setq done T) (setq d (cdr d))) (foreach e l (redraw e 4)))) (if l (sssetfirst nil (foreach e l (ssadd e s)))) (princ) )
Hey Z9,
Thanks for posting your reply. Your Lisp works very well! I will be using it often.
Thanks again,
-Mark
