CopyClip won't copy everything
eellis1P7A9H
eellis1P7A9H
Hello!
I'm trying to copy some lines from one file to another but nothing seems to work. I've tried saving it as a block or as a DXF with no luck, it shows up the same way as if I used CopyClip. There are no groups and there is nothing explode. I also tried changing the system variables and it gave me errors when trying to read the svf file.
The issue only seems to happen with this one file. I've attached a couple of photos of what I'm trying to copy and the result.
Thanks for your help!
imadHabash
i suggest to clean your source CAD dwg file :
  • use AUDIT command .
  • use -purge ( Regapps ) command .
  • use purge command .
try now and see if any changes ? if not success please attache here your CAD dwg file for testing ?
Imad Habash
eellis1P7A9H
Neither of those three worked however, it was a rhino file and I didn't realize you could import it as a 3DM file instead of exporting it as a DWG first.
