Anuncios
Copy with base point
No aplicable
We use Autocad 2016. when I use "copy with base point", a bar appears in autocad and give me the source file information. Could you please tell me, how can i disable this property. Please see attached screenshot.
Thanks.
0 Me gusta
Responder
Soluciones aceptadas (1)
823 Vistas
5 Respuestas
Respuestas (5)
regisrohde
Seems to be using XREF.
Please mark this as the solution if it resolves your issue.Kudos gladly accepted.
Regis Rohde
0 Me gusta
rkmcswain
When exactly does this appear? When you hover over the pasted objects? Before you actually paste it? Something else?
R.K. McSwain     | CADpanacea | on twitter
0 Me gusta
No aplicable
When i paste an objects, it appears.
0 Me gusta
Victoria.Studley
Solución aceptada
Hi @Anonymous,
Thank you for posting your question here in the community. The issue in your screenshot looks suspiciously like the tooltip hover problem that was fixed by AutoCAD 2016 Service Pack 1. Do you have SP1 installed?
The way it is manifesting (through copy with basepoint) seems different, although it couldn't hurt to install the service pack if you haven't done so already. Let's rule that out first, and if the issue persists once the service pack is installed, it might be helpful if you recorded a Screencast of the issue occurring, so that we can witness the behavior as it happens.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
No aplicable
Thank you so much for your help... It's worked.
Plmks
0 Me gusta
