Copy/paste problem !!!
M.ARSHAD
M.ARSHAD
i m facing problem while i copy paste object between 2 autocad file. i receive this msg
_pasteclip Duplicate definition of block _ArchTick ignored.
Substituting [SANSSB__.TTF] for [sasb____.pfb].
Substituting [ROMAB___.TTF] for [romb____.pfb].
and unable to paste in other file. i m using autocad 2012 and 2013. this problm in specific files not in all file.
pendean
Community Legend
Community Legend
1. AutoCAD stopped using PFB fonts a very long time ago: replace these in both your source and destination files now (STYLE command) or live with the prompts forever.
2. You have a nested block in your selection called _ArchTick, or your files were at some point saved in a newer version (2013 is different from 2012, a commone issue when you mix versions like that regardless of how you save the DWG file). Using -EXPORTTOAUTOCAD command in 2013 should fix the files for 2012 users. In both 2012 and 2013 remember to also go to OPTIONS command's OPEN AND SAVE tab's and uncheck the two MAINTAIN... boxes under the save as pulldown.
M.ARSHAD
i try the options u told but unable to solve the problm. even if i copy a single line it give me the same mesage.also copy paste take too much time and files are very heavy like 20-30 mb. thanks a lot
jggerth
To get rid of the messages about pfb fonts, go into the source drawing(s), run the STYLE command, and change _all_ styles that list a .pfb font to use a modern, supported font.
Then purge the heck out of them and get rid of everything that's not needed.  sounds like they've accululated a fair amount of cruft in the decade-and-a-half since postscript fonts were supported by AutoCAD
M.ARSHAD
thanks a lot everyone. problem solved with "dgnpurge"
Best regards
MUHAMMAD ARSHAD
