Copy midpoint between two objects
When copying an object to "midpoint between two objects" and using the running osnaps, I'm finding AutoCAD 2022 does not allow me to select the original object origin point (perpendicular or in line with the first selected object) after selecting the first object to copy between. Has anyone encountered this bug? I've never had this issue with the previous versions.
ian.mag
Hi @Anonymous
Not really. "midpoint between two objects" works great from my end.
Have you installed the latest updates from Autodesk? Seems to be a bug to me.
ChicagoLooper
Control+Mouse Right Click.
This will give you a snap menu so you can temporarily reactivate your snaps.
Chicagolooper
illusionistNUGXG
Is AUTOSNAP completely turned on?
The value for this is 63.
(63 is the initial value of it)
The value of AUTOSNAP can also be changed with F11, wich toggles part of it on / off.
