Copy and Paste Problem
Message 1 of 12
Hi, I would like to ask, why does Copy (Ctrl+C) and Paste (Ctrl+V) sometimes work, but most of the time, it doesnt? Hope anyone can help me with this. Thank you in advance.
Replies (11)
Message 2 of 12
m_kingdon
How am I supposed to answer this question without any detail?
Mike Kingdon
Civil 3D Zealot
Message 3 of 12
Patchy
Message 4 of 12
Hi, thanks for giving time. This is the situation, I copied a number of objects (ex. reflected ceiling plan) in a file and paste in to another. But after I paste it to the drawing area, I pasted nothing. If Im not mistaken, if you paste object/s in the drawing, there is a preview of that object/s upon specifying the insertion point. The solution that I did was, I made the object as a block using WBLOCK command, then insert it to the target file, that actually worked. But its a long procedure compared to just Ctrl+C or Ctrl+Shft+C then Paste.
Message 5 of 12
Patchy
It could be the ceiling plan was created by Autodesk Architectural, and these entities are AEC objects which you can view but cannot copy and paste to a plain autocad file.
Message 6 of 12
But the ceiling plan was made with the same program, AutoCAD 2014.
Message 7 of 12
m_kingdon
What layer is the ceiling fan on?  Usually when I copy and paste stuff and it doesn't show up, it is because I am pasting it onto a frozen layer.
Mike Kingdon
Civil 3D Zealot
Message 8 of 12
m_kingdon
Or!
The scales are different, you are pasting an object that is very big or very small compared to the other drawing.
When you click to paste the object, trying zooming into that point to see if an object appears.  If not trying punching into your keyboard Z > E for "zoom extent".  You might find the object you pasted in is massive.
Mike Kingdon
Civil 3D Zealot
Message 9 of 12
Hi sir m.kingdom, sir Patchy, I've attached here the file which I would like you to check, if you just have time. Try to copy objects and paste it anywhere in the drawing area, if it didnt work, then it wont work on another dwg file. But if it worked in your computer, then maybe the problem is in my pc. I tried to attached the file here but an error occured, so I saved it in my dropbox, and here's the the link:
https://www.dropbox.com/s/rab0t1o9ylrqiwt/Copy%20and%20Paste%20Problem.dwg?dl=0
Thank you sir,
Paul John Roxas
Message 10 of 12
you have to repair the file than try to copy hope it will work sure,
purge,audit,recover all these to repair the file
Message 11 of 12
Patchy
There are millions of no good junks in this drawing, go to the link I posted and get rid of them.
Message 12 of 12
Im looking on it now. Thank you very much.
