Copy and paste error in AutoCAD
long0212le
long0212le
When I copy any line of text, then I paste it somewhere else, the code appears completely different from what I copied before.
The original object is ATTDEF in Block
Thank you for your help
vinodkl
Hi @long0212le
Check this article: https://knowledge.autodesk.com/support/autocad-mechanical/troubleshooting/caas/sfdcarticles/sfdcarti...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
long0212le
Thank you very much
