Copy&Paste locks up computer because of "Duplicate definition of block"
adadmun
adadmun
So this is really simple. I commonly need to copy and paste the same blocks over and over again. But in some drawings, when I copy and paste a block. my whole computer locks up for a few seconds, then AutoCAD spits out "Duplicate definition of block ignored". Well, yeah- it's a copy&paste of the block, its supposed to be a duplicate. If it were blocks between separate DWGs, I would understand. But this duplicating already defined blocks within the same file.
Is there some way to shut off "Duplicate definition of block"? Or otherwise fix this? It's really slowing down my work flow, and seems very pointless. They are not even very complicated blocks.
cadffm
No, you are unsing not the right* drafting command to copy objects (copy).
*right means the right way to copy object from&to the same space int the same file.
You are using the windows clipboard (ctrl+c / ctrl+v or similar -> copy&paste),
what you do by this way: You EXPORT objects in a temporary .dwg file and import this file
back by pasting (ctrl+v for example).
Because of this, acad checking : Is there already a block defined by the same name, or not (if not, import the block first and then, paste the copied block references.
Sebastian
pendean
Community Legend
Community Legend
There is nothing unusual about the commandline feedback you see @adadmun that's a feature of the program. You can't change it if you are asking.
However, the freeze of the program is not, here is long list from Autodesk for fixes, start at the top and work through it all
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Copy-and-paste-in-...
HTH
adadmun
Thats annoying. I primarily use COPYBASE to have control over the exact point of insertion, then use CTRL+V to paste it. The built in copy command is clunky for my purposes, and would probably slow me down more than the freezing.
Is there anyway to shut this off? Or otherwise modify AutoCAD to use CTRL+C or CTRL+V without the temp file? Would making a local version of the drawing fix it?
cadffm
>>"would probably slow me down more than the freezing."
How?
Select, start copy, pick 1. point, pick 2. point - done.
(and think about custom macros)
Sebastian
