Copy & Paste blocks from excel to command line
Message 1 of 8
Hi All
I have been trying to copy & paste a block from an excel sheet when I paste into command line (-Insert Double socket 222,333) I get a box wanting a substitute block, but the block is already in the blocks file, pic attached any help would be greatly appreciated.
Chris
Replies (7)
Message 2 of 8
Moshe-A
@Anonymous  hi,
please upload the dwg + excel files
moshe
Message 3 of 8
Hi
Please find drw attached the excel sheet only has this at the moment(-Insert test 222,333)   which I am pasting into autocad command line
Regards
Message 4 of 8
Moshe-A
@Anonymous  hi,
if you want to insert a block why don't you use the insert command?
the autolisp code you are pasting is incomplete and that's why it doesn't work.
moshe
Message 5 of 8
Hi
I use pline all the time from a spreadsheet to plot lines so was hoping to do the same with a block for multiply insertions could you tell me what is missing from code
Thank you
Message 6 of 8
Moshe-A
this is a legal autolisp code line
(command "-insert" "test" "222,333" 1 1 0)
Message 7 of 8
leeminardi
You can use the Excel concatenate function to build a vlisp command to insert the cells.  I used char(34) to create the quotes around some of the parameters in the insert command.
You can copy the contents of column D off the spreadsheet into the command line of AutoCAD to add multiple instances of many blocks.
Cell D2 contains:
=CONCATENATE("(command ",CHAR(34),"-insert",CHAR(34)," ",CHAR(34),A2,CHAR(34)," ",CHAR(34),B2,",",C2,CHAR(34)," ",CHAR(34),CHAR(34)," ",CHAR(34),CHAR(34)," ",CHAR(34),CHAR(34),")")
Which yields a statement like the following:
(command "-insert" "Doors_ExtDbl_w-Glazing_Bars_1 - 1510x2110mm-10509454-Level 0" "1000,600" "" "" "")
lee.minardi
Message 8 of 8
Hi Thank you very much for your reply,but I still have the warning message,drives you crazy ? Picture attached
