Coordinates toolbar in autocad 2018/19
Message 1 of 8
My toolbar at the top of the screen doesn’t show the coordinates how do I add this to my toolbar. I’m a complete beginner at autocad and am trying to draw a 3D model
Replies (7)
Message 2 of 8
Johanna_Esteban
Hi @Anonymous,
In the icon on the lower right, check Coordinates.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
Message 3 of 8
Hi Johanna,
Which icon, would you be able to give me a step by step?
Message 4 of 8
Johanna_Esteban
Hi @Anonymous,
See attached image, click on icon (number 1) and then click on Coordinates (number 2).
Johanna Esteban
Message 5 of 8
Hi Johnna I've already got that but i still don't have the coordinates toolbar at the top where the layouts are, i've attached screenshots the first is of my autocad screen the second is the tutorial i'm trying to follow
thanks
Message 6 of 8
BrianBenton
I see what you mean now. You are looking for the Coordinates Panel in the Ribbon. You have to change the workspace. You are currently using the standard 2D drafting workspace and you need to switch to the 3D workspace. There should be a little GEAR icon at the bottom of the screen. Left-Click that. It will open a window with a list of Workspaces. A wprkspace defines which tools are on your screen in toolbars, or in the Ribbon. The Ribbon is the "toolbar" and icons across the top of the screen. So click the gear, then click on the 3D Modeling option. This will switch your Ribbon to display the 3D tools. You will then have access to the coordinates panel in the Ribbon.
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
Message 7 of 8
imadHabash
Hi and Welcome to AutoCAD Forum,
you may not find such an option as you asked . BUT you can display the coordinates of the cursor by press F12 . also you can right-click the button ( down in the status bar ) to chose the type of coordinates to display. please read and follow this AKN article that may help . >> Click <<
Imad Habash
Message 8 of 8
ChicagoLooper
You are describing the Coordinates Panel, not the coordinates toolbar. To get the coordinates panel, you will need to change your workspace to 3D Modeling. See image below.
Change your workspace to '3D Modeling.'Change your workspace to '3D Modeling.'
Chicagolooper
