Hi all.
Im new to this forum and thought why not ask here also pretty new to geolocation coordinates in autocad 🙂
I have autocad drawing using ETRS GK27 geomap and model is in correct coordinates. ETRS GK27 uses metric values so that 1 unit equal 1 m.
is there a way to input values as mm when you for example draw a line so that it will be 1 unit long in model? Dynamic input does not seem to allow me to type 1000mm for example. What would make 1 unit lenght of a line.
1000 input value for 1m line is out of question because it would mess locations to ETRS GK27 locations.
Atleast dimensioning can be scaled to give 1000 lenght to 1 unit long line.
Hopefully you understand the question, don't know how to better decribe what im after. I just wish I could draw inputting mm values and it would still match with ETRS GK27 system. Also if I remember right in Microstation this can be done throu master units/sub units. (not 100% sure about this).
-Marko
