Coordinates and insertion points
anch2304
anch2304
The coordinates in the drawings are shown differently (look at the pictures). Do you know why? How can I change the properties for the coordinates?
Accepted solutions (4)
Valentin_CAD
@anch2304 ,
Try the suggestion posted here:
https://www.cadforum.cz/en/displaying-large-coordinates-without-the-scientific-notation-tip7417
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Edwin.Rense
The difference in the coordinates has to do with the large numbers (coordinate values).
The larger numbers are 'simplified' to show the E+09 values. So the Coordinates shown should be multiplied with 10^9.
(If this is the correct way to write it, is stands for 10*10*10*10*10*10*10*10*10=10.000.000.000)
It has to do with the need for precision (significant number) so with the larger number only the most important number is shown, the rest is shortened to the E value.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
imadHabash
Set the COORDS system variable to 0 for static display, 1 for dynamic display, or 2 for distance and angle display.
Imad Habash
Kent1Cooper
[10^9 is actually "only" 1,000,000,000, but nevertheless....]
My question for @anch2304 :  Do you need to be working that far from the drawing origin?  At some degree of hugeness that will start to cause other problems than just the scientific-notation coordinates display.
Kent Cooper, AIA
