Coordinate blocks distance measurement
alxnds5
Message 1 of 14
alxnds5
Hello, I'm wondering if someone can help me. I've created coordinate blocks in a drawing I'm working on but I need the distance between the 2 blocks. Is there any command that will provide the x and y distances between the two? I need to account for both distance and sum them up.
This needs to be done for a lot of blocks so I'm wondering if there is a table that can also be extracted for AutoCAD.
Replies (13)
Message 2 of 14
TheCADnoob
Message 3 of 14
alxnds5
I am using data extraction currently and thereafter formulating an equation that will find the overall length (account for x and y differences) but I'm wondering if there is a faster method as I have close to 100 blocks.
Message 4 of 14
john.vellek
Hi @alxnds5,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Take your data extraction and drop it into an Excel spreadsheet.  Form there you should be able to do the math failry easily.
John Vellek
Message 5 of 14
Kent1Cooper
@alxnds5 wrote:
.... I need the distance between the 2 blocks. .... I need to account for both distance and sum them up. ....
(defun C:TEST (/ blksel1 blksel2)
  (setq
    blksel1 (entsel "\nSelect one Block: ")
    blksel2 (entsel "\nSelect other Block: ")
    delta (mapcar '- (cdr (assoc 10 (entget (car blksel1))))  (cdr (assoc 10 (entget (car blksel2)))))
  ); setq
  (prompt
    (strcat
      "\nSum of X & Y distances between Blocks = "
      (rtos (+ (abs (car delta)) (abs (cadr delta))))
    ); strcat
  ); prompt
  (princ)
); defun
That's just the summation-of-XY part, not the further stuff [e.g. table].  If I've misunderstood, give more detail about what you need, what steps the User would take, the nature of the Blocks, etc.
Kent Cooper, AIA
Message 6 of 14
alxnds5
Hi Kent,
I tried the code but I'm not able to get anything, not sure if there is something additional I have to input. To give you a better idea of what I need I've attached a sample image, so basically what I need is to distance (sum of x and y) from the coordinates up top to the box labeled "1" at the bottom.
For example a method that would calculate distance using the coordinates (52,470) to the coordinates at the bottom (71,20). I have to do this repeatedly with many columns so anything to expedite the process and make it more effective would be great.
Message 7 of 14
Kent1Cooper
@alxnds5 wrote:
.... I tried the code but I'm not able to get anything....
Are they not Blocks?  If they are, are their insertion points at the locations you want to measure between?  When you try it, what do  you get?  Any error messages?
Kent Cooper, AIA
Message 8 of 14
alxnds5
I created a coordinate block  (in green) and placed them at different points as you can see on the image. You are correct I want the distance between them. So distance between 1 to box 1, 2 to box 1 and 3 to box 1 (x and y included, so the perpendicular path not just the linear).
Upon pasting the code I cannot pick the block, perhaps I don't know how to use the code. I apologize I'm not too familiar with coding through AutoCAD.
Message 9 of 14
Kent1Cooper
The code defines a command name.  It doesn't "do the work" until you call for that command.  If you're just pasting the code into a drawing, then you still need to type TEST to run it.  If it does what you want, save it as a file with a .lsp filetype ending that you can then APPLOAD in any drawing, and change that TEST command name to something more meaningful.
Kent Cooper, AIA
Message 10 of 14
alxnds5
I was able to get it, thank you so much Kent. Do you know of any command that would compile the data in this case the distances in a table format?
Message 11 of 14
Kent1Cooper
@alxnds5 wrote:
.... Do you know of any command that would compile the data in this case the distances in a table format?
I don't, and I've only rarely used Tables, and never in AutoLisp.  Search the Customization Forum, and you may find something that builds a Table from collected information.
Kent Cooper, AIA
Message 12 of 14
john.vellek
HI @alxnds5,
This should be workable in Excel. You capture all the blocks with their insertion points and you can perform the same kind of math that @Kent1Cooper's routine does for the two individual blocks.
John Vellek
Message 13 of 14
alxnds5
I'm not quite sure that would work considering its several blocks connecting to one main block. They don't interconnect among one another so I don't know how I would be able to get an accurate total distance. As far as extracting data, I don't know if these distances would be able to be extracted apart from manually writing each one manually in an excel.
Message 14 of 14
alxnds5
I have one last question, I'm sorry. Is it possible to modify your code so that there is one main block chosen and thereafter pick multiple blocks that have a path to the main block?, that way it adds all the distances to that one main block.
