Converting multiple DWG files to PDF quickly
janda_bohuslav13
Observer
janda_bohuslav13
Observer
Observer
Hello everyone, I got a question that regards to converting multiple DWG files with multiple sheets into a multiple multiple sheet PDF files quickly. For instance, I have 65 technical drawings and I need to export them into a PDF file quickly without needing to open every each of them and export them to a PDF file. I had an idea to convert it by using a online converter but I don't really trust these websites and I don't want those drawing to be stuck somewhere in a database.
In advance, thank you.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.739 Vistas
5 Respuestas
Respuestas (5)
Jason.Piercey
Solución aceptada
I publish multi-sheet PDF files via the Sheet Set Manager. Using the pagesetup override option has worked best for me.
janda_bohuslav13
Observer
Observer
I will try my best to figure it out tomorrow at my job. Thank you! @Jason.Piercey
0 Me gusta
Tomislav.Golubovic
Tried with the PUBLISH command?
0 Me gusta
janda_bohuslav13
Observer
Observer
No, but i'll try
0 Me gusta
baksconstructor
This can happen automatically:
1. Opens each file separately.
2. Creates a separate multi-page PDF for each file. The file will only contain Layouts from one file.
To do this, in the settings you need to select - Search in folder and specify all your files that need to be created as PDF.
Link - Revers
P.S. Why are you marking as a solution something that you haven’t checked yet?
0 Me gusta
