Hello. I have a similar issue, but would like some help.
I'm using an existing 3D piece that was drawn by someone else and needed to explode it to update the size of the piece. Note: Not sure how the original piece was created, so that's the reason for this inquiry.
I tried your EDGESURF command and it did a portion of it like the original piece and I've tried the LOFT command, which did some of it, as well, but there is one section that I'm unable to do with either of these commands (unless I'm not doing something correctly.) In the drawing attached, the image on the right is the original piece, the image on the left is the piece I'm working with at the size I need it at. Any suggestions on how I can fix the bottom part of the left image to look like the one on the right? I've clouded the area in question in the drawing. Thanks for the help.
