Converting AutoCAD Drawing to dxf file
Kindly assist us with an issue with the AutoCAD drawing converting to dxf file. The figures are mostly crossing the border of the table after the conveetion. We already applied the service pack 1 for AutoCAD and it’s still the same issue.
See attached converted dxf file.
Thanks.
Ericson Dorado
Slawomir_
Which command do You use to export?
pendean
Community Legend
Community Legend
What is your AutoCAD version? What is your AutoCAD variant?
What format DXF are you trying to create? What command are you using?
Are you actually using a TABLE object type in AutoCAD? Or just lines and single TEXT objects?
What font are your text styles using?
I see the mess on the right side, but it's not messy at all at the bottom: so what is the difference?
TheCADnoob
As far as i know dxf do not include local fonts when they are created using the saveas method.
When i open the DXF i get the missing font issue.
I believe you can include the font by using the ETRANSMIT command.
CADnoob
john.vellek
Good morning @Anonymous,
Welcome to the forums!
I'm looking at your dxf file and see that text running over the lines in your table. Can you attach your original drawing to see if I can help to improve the process for you?
John Vellek
john.vellek
I have not seen an update to your post so I am checking back to see if my post or those of others  helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
