Converting 2D Polylines to surfaces - Retaining verticies along edges
Apologies if this is a double post. This forum is giving me problems as well as the software.
I've recently upgraded from AutoCAD 2016 from 2008. When I use "convtosurface" on a 2D polyline the resulting surfaces no longer has verticies along straight edges along the surface's perimiter. This happens most of the time but not always. Is there a setting or a command I can use such that verticies on straight edges are retained when turned into a planar surface? This is very important to my work flow, and I'm really hoping for a solution.
I've attached a test file. Try using "convtosurface" on these polylines, and you'll see 1 of them retains it's verticies, the other two don't. Again, why is this, and how can I for the system to retain all verticies?
Here is an attempt of a screenshot to illustrate my point, but I"m not sure if it will work on this forum. And since, I can't edit a post, if it doesn't post, well I did my best.
<a href="http://s103.photobucket.com/user/Gobc12/media/SurfaceVertex_zpsgmi8nfxt.png.html" target="_blank"><img src="http://i103.photobucket.com/albums/m138/Gobc12/SurfaceVertex_zpsgmi8nfxt.png" border="0" alt=" photo SurfaceVertex_zpsgmi8nfxt.png"/></a>
