Convert To Solid
Convert To Solid
Convert To Solid
i'm wanna make my 3D Turbine Desain as a solid. I've tried "explode" and "convtosolid"  and always fail. i dont have idea what i must do now to convert it as a solid body
ennujozlagam
you can try to refer to this LINK and see if helps. thanks
tramber
You can use _THICKEN
But it will only thicken your surfaces.... Smiley Happy
skintsubby
Hi @Anonymous
You can't turn an arc or line into a solid.
You need to give it depth as well.
See attached.
parkr4st
or maybe like the attached
davinatkins
Tramber is correct
If you use the thicken command - and tell it how thick you want the surface to be - it will convert it to a solid for you. 2D objects like a surface can't be a solid since they don't technically have volume.
