Try this
;;---------------------=={ Polyline Information }==---------------------;;
;; Author: Lee Mac, Copyright © 2014 - www.lee-mac.com ;;
;; Version 1.0 - 2012-07-10 ;;
;; - First release. ;;
;; Version 1.1 - 2012-07-16 ;;
;; - Added Table & Text file output options. ;;
;; - Removed basic LWPolyline properties. ;;
;; Version 1.2 - 2014-06-14 ;;
;; - Fixed bug causing final segment to be omitted from output data ;;
;; when processing closed polylines. ;;
;; Version 1.3 - 2015-04-13 ;;
;; - Fixed bug causing the program to crash when processing polylines ;;
;; containing arc segments. ;;
(defun c:polyinfo ( / *error* ent enx flg ins lst out seg tmp )
(defun *error* ( msg )
(LM:endundo (LM:acdoc))
(if (= 'str (type out)) (setenv "LMac\\PolyInfo" out))
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ (strcat "\nError: " msg))
(princ)
(if (null (setq out (getenv "LMac\\PolyInfo")))
(setq out "TXT")
(princ
(strcat "\nOutput Format: "
(cond
( (= out "TXT") "Text File")
( (= out "CSV") "CSV File")
( "AutoCAD Table" )
(while
(progn
(setvar 'errno 0)
(initget "Output")
(setq ent (entsel "\nSelect polyline [Output]: "))
(cond
( (= 7 (getvar 'errno))
(princ "\nMissed, try again.")
( (null ent)
nil
( (= "Output" ent)
(polyinfo:chooseoutput 'out)
(princ
(cond
( "AutoCAD Table" )
( (/= "LWPOLYLINE" (cdr (assoc 0 (entget (setq ent (car ent))))))
(princ "\nSelected object is not an LWPolyline.")
(cond
( (and
(= 'ename (type ent))
(= "Table" out)
(= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (getvar 'clayer))))))
(princ "\nCurrent layer locked.")
( (= 'ename (type ent))
(setq seg 0
enx (entget ent)
lst (LM:lwvertices enx)
lst
(cons
(append '("SEG." "START X" "START Y" "END X" "END Y" "WIDTH 1" "WIDTH 2" "LENGTH")
(if (setq flg (vl-some '(lambda ( x ) (not (zerop (cdr (assoc 42 x))))) lst))
'("CENTRE X" "CENTRE Y" "RADIUS")
(mapcar
(function
(lambda ( l1 l2 / b p q )
(setq p (cdr (assoc 10 l1))
q (cdr (assoc 10 l2))
b (cdr (assoc 42 l1))
(append
(list (itoa (setq seg (1+ seg))))
(mapcar 'rtos p)
(mapcar 'rtos q)
(list
(rtos (cdr (assoc 40 l1)))
(rtos (cdr (assoc 41 l1)))
(if (zerop b)
(cons (rtos (distance p q)) (if flg '("" "" "")))
(append
(list (rtos (abs (* (LM:bulgeradius p q b) (atan b) 4))))
(mapcar 'rtos (LM:bulgecentre p q b))
(list (rtos (LM:bulgeradius p q b)))
lst
(if (= 1 (logand 1 (cdr (assoc 70 enx))))
(append (cdr lst) (list (car lst)))
(cdr lst)
(cond
( (= out "TXT")
(if (LM:writetxt lst (setq tmp (vl-filename-mktemp (cdr (assoc 5 enx)) (getvar 'dwgprefix) ".txt")))
(startapp "explorer" tmp)
( (= out "CSV")
(if (LM:writecsv lst (setq tmp (vl-filename-mktemp (cdr (assoc 5 enx)) (getvar 'dwgprefix) ".csv")))
( (setq ins (getpoint "\nSpecify point for table: "))
(LM:startundo (LM:acdoc))
(LM:addtable (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)) (trans ins 1 0) nil lst nil)
(princ)
;; Add Table - Lee Mac
;; Generates a table at the given point, populated with the given data and optional title.
;; spc - [vla] VLA Block object
;; ins - [lst] WCS insertion point for table
;; ttl - [str] [Optional] Table title
;; lst - [lst] Matrix list of table cell data
;; eqc - [bol] If T, columns are of equal width
;; Returns: [vla] VLA Table Object
(defun LM:addtable ( spc ins ttl lst eqc / dif hgt i j obj stn sty wid )
(setq sty
(vlax-ename->vla-object
(cdr
(assoc -1
(dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "acad_tablestyle")))
(getvar 'ctablestyle)
(setq hgt (vla-gettextheight sty acdatarow))
(if (LM:annotative-p (setq stn (vla-gettextstyle sty acdatarow)))
(setq hgt (/ hgt (cond ((getvar 'cannoscalevalue)) (1.0))))
(setq wid
(mapcar
'(lambda ( col )
(apply 'max
(mapcar
'(lambda ( str )
( (lambda ( box ) (if box (+ (* 2.5 hgt) (- (caadr box) (caar box))) 0.0))
(textbox
(list
(cons 01 str)
(cons 40 hgt)
(cons 07 stn)
col
(apply 'mapcar (cons 'list lst))
(if
(and ttl
(< 0.0
(setq dif
(textbox
(list
(cons 01 ttl)
(cons 40 hgt)
(cons 07 stn)
(apply '+ wid)
(length wid)
(setq wid (mapcar '(lambda ( x ) (+ x dif)) wid))
(setq obj
(vla-addtable spc
(vlax-3D-point ins)
(1+ (length lst))
(length (car lst))
(* 2.0 hgt)
(if eqc
(apply 'max wid)
(/ (apply '+ wid) (float (length (car lst))))
(vla-put-regeneratetablesuppressed obj :vlax-true)
(vla-put-stylename obj (getvar 'ctablestyle))
(setq i -1)
(if (null eqc)
(foreach col wid
(vla-setcolumnwidth obj (setq i (1+ i)) col)
(if ttl
(progn
(vla-settext obj 0 0 ttl)
(setq i 1)
(progn
(vla-deleterows obj 0 1)
(setq i 0)
(foreach row lst
(setq j 0)
(foreach val row
(vla-settext obj i j val)
(setq j (1+ j))
(setq i (1+ i))
(vla-put-regeneratetablesuppressed obj :vlax-false)
obj
;; Write CSV - Lee Mac
;; Writes a matrix list of cell values to a CSV file.
;; lst - [lst] list of lists, sublist is row of cell values
;; csv - [str] filename of CSV file to write
;; Returns T if successful, else nil
(defun LM:writecsv ( lst csv / des sep )
(if (setq des (open csv "w"))
(progn
(setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
(foreach row lst (write-line (LM:lst->csv row sep) des))
(close des)
t
;; List -> CSV - Lee Mac
;; Concatenates a row of cell values to be written to a CSV file.
;; lst - [lst] list containing row of CSV cell values
;; sep - [str] CSV separator token
(defun LM:lst->csv ( lst sep )
(if (cdr lst)
(strcat (LM:csv-addquotes (car lst) sep) sep (LM:lst->csv (cdr lst) sep))
(defun LM:csv-addquotes ( str sep / pos )
(cond
( (wcmatch str (strcat "*[`" sep "\"]*"))
(setq pos 0)
(while (setq pos (vl-string-position 34 str pos))
(setq str (vl-string-subst "\"\"" "\"" str pos)
pos (+ pos 2)
(strcat "\"" str "\"")
( str )
;; Write Text File - Lee Mac
;; Writes a matrix of values to a tab-delimited Text file.
;; lst - [lst] list of lists, sublist is line of text values
;; txt - [str] filename of Text file to write
(defun LM:writetxt ( lst txt / des )
(if (setq des (open txt "w"))
(progn
(foreach itm lst (write-line (LM:lst->str itm "\t") des))
(close des)
t
;; List to String - Lee Mac
;; Concatenates each string in a supplied list, separated by a given delimiter
;; lst - [lst] List of strings to concatenate
;; del - [str] Delimiter string to separate each item
(defun LM:lst->str ( lst del )
(if (cdr lst)
(strcat (car lst) del (LM:lst->str (cdr lst) del))
(car lst)
;; Annotative-p - Lee Mac
;; Predicate function to determine whether a Text Style is annotative.
;; sty - [str] Name of Text Style
(defun LM:annotative-p ( sty )
(and (setq sty (tblobjname "style" sty))
(setq sty (cadr (assoc -3 (entget sty '("AcadAnnotative")))))
(= 1 (cdr (assoc 1070 (reverse sty))))
;; LW Vertices - Lee Mac
;; Returns a list of lists in which each sublist describes
;; the position, starting width, ending width and bulge of the
;; vertex of a supplied LWPolyline
(defun LM:lwvertices ( e )
(if (setq e (member (assoc 10 e) e))
(cons
(list
(assoc 10 e)
(assoc 40 e)
(assoc 41 e)
(assoc 42 e)
(LM:lwvertices (cdr e))
;; Bulge Radius - Lee Mac
;; p1 - start vertex
;; p2 - end vertex
;; b - bulge
;; Returns the radius of the arc described by the given bulge and vertices
(defun LM:bulgeradius ( p1 p2 b )
(/ (* (distance p1 p2) (1+ (* b b))) 4 (abs b))
;; Bulge Centre - Lee Mac
;; p2 - end vertex
;; b - bulge
;; Returns the centre of the arc described by the given bulge and vertices
(defun LM:bulgecentre ( p1 p2 b )
(polar p1
(+ (angle p1 p2) (- (/ pi 2) (* 2 (atan b))))
(/ (* (distance p1 p2) (1+ (* b b))) 4 b)
;; Start Undo - Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
(LM:endundo doc)
(vla-startundomark doc)
;; End Undo - Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
(while (= 8 (logand 8 (getvar 'undoctl)))
(vla-endundomark doc)
;; Active Document - Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
(eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
(LM:acdoc)
(vl-load-com)
(eval
(append
(list 'defun 'polyinfo:chooseoutput '( sym ))
(if (vlax-method-applicable-p (vla-get-modelspace (LM:acdoc)) 'addtable)
(list
'(initget "Table TXT CSV")
'(set sym (cond ((getkword (strcat "\nChoose Output [Table/TXT/CSV] <" (eval sym) ">: "))) ((eval sym))))
(list
'(initget "TXT CSV")
'(set sym (cond ((getkword (strcat "\nChoose Output [TXT/CSV] <" (eval sym) ">: "))) ((eval sym))))
(princ
(strcat
"\n:: PolyInfo.lsp | Version 1.3 | \\U+00A9 Lee Mac "
(menucmd "m=$(edtime,0,yyyy)")
" www.lee-mac.com ::"
"\n:: Type \"polyinfo\" to Invoke ::"
(princ)
;; End of File ;;
