Convert Block Reference into 3D Solid
I'm trying to export my DWG file out as an STL, but apparently first I need to convert my block reference into a 3D solid. I just keep getting the error "Object cannot be converted". I'm a complete AutoCad n00b so would appreciate any advice or help you can give. Thanks!
j.palmeL29YX
Before converting this polyface mesh into a solid (this can be a hard way) I'd suggest to model it from scratch as shown in the attachment.
HTH
cadder
Jürgen Palme
beyoungjr
Usually you can just explode a block of a solid model and all is well but your drawing was created in some other program.  If I explode I get polyface mesh objects and thousands of lines.
I simply traced a polyline around the bottom flat portion of the object, ignoring the "bull nose", from start of the arc to other end.  I closed the polyline across the arc.
I created a 3 point circle to develop the arc but I noticed that the round profile does not match your model by zooming in and comparing the arc to the block object.
Instead of arc I created a flat spline around the arc using all of the bottom endpoints at the "bull nose" transition.  I then copied the spline and frame, trimmed the frame, and joined the entire profile to get the matching flat for your object.
I extruded the joined profile to get a solid.
I then copied the solid and extracted edges to get just the bottom front profile and I swept a bull nose profile along that path, creating a solid.
I copied the bull nose solid to the flat solid and union the two as one solid object.
Now the object can be exported as a proper watertight stl model.
BTW, I tried to explode the block and just export to stl but it fails.
Hope this helps,
Blaine
Blaine Young
Senior Engineering Technician, US Army
Thanks for the super detailed instructions, they're really helpful!
Hope this helps,
Blaine
j.palmeL29YX
After exploding the blockreference you get a Polyface Mesh.
Depending on you ACAD version (in ACAD Rel. 14, the current format of your drawing, this is not yet possible) this Polyface Mesh mesh can be converted into a solid with the following steps:
(- Explode the blockreference, you get Polyface Meshes)
- Explode the Polyface Meshes, you get 3DFaces
- Convert the 3DFaces to Surfaces (CONVTOSURFACE)
- Create the 3DSolid (SURFSCULPT)
You get an identical "clone" of your block reference as 3DSolid.
https://autode.sk/2Eg7WdK
cadder
Jürgen Palme
j.palmeL29YX
Attached a similar, but slightly different way to get the result.
https://autode.sk/2yB8qp1
(The creation of the spline was shortened a bit (clipped) in the video)
cadder
Jürgen Palme
This worked. Thanks
