Convert Autocad dwg to step
jjmill1
jjmill1
I have to convert a 2D drawing to a step file for a 5 axis water jet cutter, and I have no clue where to start.  Can anyone help with this.
I am to convert it to step and thay change it to an org file apparently.  I found the export to iges, and would like to know if thats the same as as step file
pendean
Community Legend
Community Legend
Do you have access to Autodesk Inventor?
jjmill1
No I don't
BeKirra
If you use AutoCAD Mechanical, the "stepout" is the command.
Otherwise, try command "export",  then choose "stl" or "igs" in files of type.
Note: This only helps if a stl or igs file can be accepted in your case.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
