Convert 3D faces to 3D solid
tsakani
tsakani
I have a structure that is made up of 3D faces that I want to convert to a 3D solid. I've tried to convert it to a surface, then thicken it but when I use the convert to 3D solid it doesn't allow it. I've also checked through the forum but all the topics seems not to help me achieve this. The attached is a mine tunnel made up of 3D faces due to the complexity of its curvature. I could change it but all existing designs are like that but I'd like to be able to calculate volumes, which are easier using 3D solids than 3d faces
Replies (8)
autoid374ceb4990
I do not see any attachment????
tsakani
I didn't notice that i forgot to add an attachment
autoid374ceb4990
If all of your tunnels are as simple as your drawing, just multiply the end area by the length.
leeminardi
YOu can use the region command to convert 3dfaces to regions.  Surfsculpt can then be used to create a solid.  For your model surfsculpt could not find a watertight model so I added planar surfaces aligned with the ends and then successfuly used surfsculpt.
lee.minardi
autoid374ceb4990
Just out of curiosity because I am using a really old AutoCAD version (R14) with no SURFSCULPT command, what was your volume calculation?
parkr4st
The root cause is apparently the ends do not align to the top.  Zoom in and there is a gap along much of the edges.
Is the "bottom" surface not level?
plines outer edge both ends and loft.   MaSSPROP Vol is 265.8948 cubic units
leeminardi
265 seems resonable as box containing the object would be 12x5x5 = 300 and the volue should be lest than that.
lee.minardi
tsakani
That worked. However, I used the patch function on each end, then surfsculpt to a 3d solid. The volume is 265.8996. Thanks alot
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
