continuing a line along its established trajectory
mikegera
mikegera
Please see attached .DWG file.
Say I want to start a line at Point "A", have it continue through Point "B" and terminate at Line "C".
The way I do this now is, with the "Node" OSNAP enabled,  draw a (L)ine from Point "A" to Point "B", then (EX)tend it to Point "C".
I feel like there must be a more efficient way.
Thanks for any replies.
user181
Try turning on the osnap "Extension" after you click point a and b it will follow the same angle of that segment
richard_387
If you want to end up with a single line, then your way is the only way.
Other solutions will give you a line in two segments, A to B and B to line C.
Patchy
Use RAY command and trim but it saves you no step.
mikegera
Thanks for the replies.  I think the RAY command (which I was unaware of) plus TR(im) is the most efficient workflow.
