Constraints command using
When use geometrical,dimensional & parametric Constraints in drawing file, Autocad giving Low memory(running out of memory) error and sometime its gets hanging.
kindly give the solution for same.
imadHabash
Hi and Welcome to AutoDesk Forum,
i suggest to download the latest Service packs from here >> Link <<
Imad Habash
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Which version of AutoCAD do you use, which operating system do you have, how much memory is built in into your system and how complex are your drawing (10 constraints, hundreds or thousands)?
Without these info's we can't say anything helpful, a drawing with your issues would be great to see too. 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Dear Sir,
We using Auto Cad 2011 version with windows 7 Ultimate edition with 4 GB
system memory.
About constraints, we use nearly 500-600 constraints in a drawing file and
simultaneously 4-5 such files are open during working. Also note we apply
these constraints only for 2D drawings.
Regards
Ravi
Alfred.NESWADBA
>> with 4 GB system memory.
Assuming you are on a 64bit operating system (and not 32bit): 4GB means you are on the absolute lowest limit of the CAD on an 64bit OS.
This means your files are used in a way that needs more than the "absolute minimum" of memory.
In case you do have a 32bit Windows 7 you probably need to change to 64bit and you have to build in more memory.
>> Also note we apply these constraints only for 2D drawings.
Doesn't matter, the constraints are only working 2D (in AutoCAD).
- alfred -
Alfred NESWADBA
