AutoCAD Forum
connvert polyline to surface
5 REPLIES 5
709 Views, 5 Replies
i made a polyline and i need to convert it to a surface so that i could export it to ansys, but all commands to do that aren't working, what should i do ?
5 REPLIES 5
Alfred.NESWADBA
It's not clear what you describe, are you wanting to fill the area of the polyline with a surface?
In that case you might use command _PLANESURF with option _OBJECT ... but if that works for the object you have shown in your screenshot? I don't know which object type that is, also not if it's on a plane or 3D, ...
If that does not help please show the dwg-file, and maybe describe what you expect to get, as my guess that the area within your polygon could be wrong.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
i want this object to be a surface so that i can extrude or something like that then i will save it into iges extension.
leeminardi
The polyline has 549 vertices.  Way too many, especially for a finite element analysis.  In addition, the shape is not closed. Use pedit then c to close the shape.  You can then use extrude to make the shape a 3D solid object.  But first, you should really clean up the shape.  Use arcs if possible for the portions of the outline that appear circular.   Better yet, use a spline to define the entire shape.  I would  think you could use less than fit points to adequately define the outline for FEA.
lee.minardi
parkr4st
in reply to: leeminardi
open at the red circle.  closed by moving end point to the left of the gap in the view and properties to closed.  extruded
dave
i am really thankful for all of you, i closed the shape then made it surfplane then import it to ansys with 2d settings
Forma Design Contest
