Connecting Points
Connecting Points
yogeshnairvarkala
Connecting Points
yogeshnairvarkala
Gud morning... I am looking for a help in Autocad Civil 3d.am having survey points from site.I want to connect this using 3d poly ..Usualy am connecting by clicking the points one by one and connecting with 3dpoly.Bit i want to know is there any alternate way to connect points with a lisp or any command by entering the point number one by one in the command prompt and connect.If there is any solution for this please help me in this issue to sort it out...Thanks buddies
Alfred.NESWADBA
When you start command _3DPOLY and then you are asked for the point (to click) you can use
'PN<ENTER>
....and now enter the Civil 3D point number (and continue with point numbers).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Kent1Cooper
@yogeshnairvarkala wrote:
.... I am looking for a help in Autocad Civil 3d.....
There's a Forum dedicated to that.
Kent Cooper, AIA
