Conditions for Layers?
amber.baysinger
amber.baysinger
I was curious, I think the answer might be no, if you can have one layer control another layer. For example, if I turn on the girder layer, it will turn off the balcony layer without manually turning it off? If this is possible, it would greatly help our production.
Thanks!
Patchy
Ask the customization group. It sound very possible.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
amber.baysinger
Thanks! Will do!
Michiel.Valcke
Although you could use a lisp with built in reactors (custumization boards), it sounds very cumbersome and difficult to maintain, especially when you want to change the relations between the layers. You could instead make layer groups. These you can lock/freeze/turn off as a group. All the layers in the group will change as you change the status of the group and you can still change the layers individually. If you want to have several representations of your layers pre-saved, take a look at layerstates instead
ara_neresesian
hi
i using macro to do things like this
Kent1Cooper
[See the >Topic in the Customization Forum< where this has been picked up.]
Kent Cooper, AIA
