AutoCAD Forum
Computer is frozen
5 REPLIES 5
1595 Views, 5 Replies
Computer is frozen
I just spent 5 hrs on a drawing and it froze, how do I save the drawing now, I'm screwed
5 REPLIES 5
ennujozlagam
@Anonymous  hello. you cannot do anything maybe try to keep  pressing you  esc button keyboard until so see the drawings i'm not sure if this works for you, your second option is to look the last save - autosave backup. thanks
pendean
You never manually saved in 5-hours?
Did you at least turn on autosave? If yes, go to your Windows log-in Temp folder and look for a file with the extension SV$ with a time stamp within those 5-hours, rename the extension to DWG and pray it has enough for you to recover from.
TheCADnoob
Frozen computer?
But seriously, if it is still 'thinking' i would give it some time and hope that past experience is wrong this time.
in addition to the method @pendean mentioned you can do the same trick on a .bak file. Do you know if your setup generates the backup files?
CADnoob
I tell all new CAD techs to get in the habit of typing QSAVE every 15 minutes or so. It is a good habit to form. It took a sticky note on my monitor for a couple of months and I type it without even thinking about it now.
john.vellek
Hi @Anonymous,
With the great suggestions in this thread I hope that you were able to recover some, if not all, of your work. Please let me know if you need additional assistance with the issue.
Here are some links that might help you for the future:
John Vellek
Forma Design Contest
