Complex drawing with multiple layouts
No aplicable
Greetings,
I am attempting to setup a rather complex drawing. The ultimate goal of my efforts is to have a sheetset that will plot out multiple layouts from one drawing. The complex part is I wish for each layouts viewport to look at the same location while only having to adjust one viewport. In order to capture all the information needed per layout I would also require that each layouts viewport be setup in a different layer state. Would anyone know how I could best go about doing this?
My current progress with this is I have all of the layouts in one document which has the corresponding files xref'd in on separate layers.
0 Me gusta
Responder
Soluciones aceptadas (1)
465 Vistas
4 Respuestas
Respuestas (4)
john.vellek
Solución aceptada
Hi @Anonymous,
This doesn't sound all that tricky actually.  If you would like to attach your files I could help walk you through this step by step.
In the mean time this is how I would start.
Create your master file, insert your xref(s).
Now go to the first layout and create the viewport in the location and size you want.
Double-click in the viewport and freeze, thaw, etc the layers to the condition you desire. Create a layer state for that particular viewport.
Now copy the Layout to a new one.
Open the viewport and again adjust the layers. Create a unique layer state for that viewport.
Do this as many times as necessary.
Make sure that your Visretain is set to 1 (on)
Next, create a new sheet set and import your layouts.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
scot-65
As Mr. Vellek suggested and my $0.02 worth...
Consider layer prefixing for each assembly/element.
A 2-character prefix followed by a dash or underscore
can be a starting point. That way, iterating thru each
viewport might be easier. When done, save as a DWT
for future use.
There will be "common" layers between each layout
and one is able to control the line weights of the visible
layers inside the viewports (example: change the vplayer
color if using CTB).
And Welcome to these Forums!
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
john.vellek
Hi MHiga,
I am checking back to see if my post or others helped you with your problem.
Please add a post with your results so other Forum users can benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
0 Me gusta
No aplicable
Sorry for the late response, I have been away on business. yes I do believe this should solve the issue im working through.
0 Me gusta
