It's impossible to tell from the image whether its "wanderings" are completely random, or whether there's a repeat. It would be essential for defining a Hatch pattern that there be some regular repeat. Can you post a larger sample, showing [for example] at what distance and direction that three-lobed closed shape in the middle recurs, and whether what wanders around it does so in a repetitive way?
EDIT: A single Block like this:
with its insertion point in the middle, Arrayed [non-associatively], can make a pattern like that with any kind of random wanderings you like, just by changing the rotation angle of some of them to 90°:
And it has big advantages over a Hatch pattern. It can contain the color infill instead of only linework, and it can have true curvature instead of needing to be made of only line segments.
Kent Cooper, AIA
