commands are not taking properly
No aplicable
hi, i have a issue regarding the commands when i enter the command as L it is not taking the line command it is taking to last angle and in some cases it is showing invalid command , plz help me out of this .
0 Me gusta
Responder
349 Vistas
2 Respuestas
Respuestas (2)
vinodkl
Looks like the program parameter file(.pgp) has been messed up. Try resetting the AutoCAD to defaults. Here is how you can do that : Click here
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
ara_neresesian
Hi
try to type full command name. or use menu bar
if with full  command name or menu bar everything is ok ,then
1- you must check "aliasedit" or pgp file. with  menu Tools/customize/edit program parameters (acad .pgp)
good luck
0 Me gusta
